Pipe Network Profile
Message 1 of 11
I have an issue in pipe network profile as it is not matching the same level as alignment, in profile its is giving some offset and showing the drainage structure below the alignment. see the picture for better understanding,
Replies (10)
Message 2 of 11
wfberry
Rt. click your structure and select properties, make sure your alignment is shown and not NONE.
Bill
Message 3 of 11
doben
Right click on a structure >Structure Properties > Reference Surface
Set it to the your surface.
Message 4 of 11
thanks, both of you @wfberry  @doben
the reference surface is already set as alignment but still it is not attached to the alignment as you can see in picture below.
Message 5 of 11
doben
Does the pipe network fall exactly on the alignment?
The profile will show the ground at the alignment so the structure rims will appear to be shown above or below even though they are on the surface. Your image shows the insertion surface elevation  and insertion rim elevation both as 774.66 and Automatic Surface Adjustment is enabled so it seems to be correct.
ID the surface at the structure to see if it matches.
Hope this helps.
I had another look at your image and it shows Structure Offset as 19'
Message 6 of 11
hello @doben
the structure offset of -19 is how far the sewer manhole is from the center line of the road.
My question is that in the section view the top of manhole is aligned with base course of the road corridor, it should be on the the top of the road corridor, its rim elevation.
How i can take it to the top of the corridor? It has a different of 0.5 feet.
Message 7 of 11
Sinoj.Ravindran
Dear Kumar,
What I understood is that your manhole is located not on the pgl of road, but there is an offset from the pgl line, and hence there is a cross slope to be calculated from the road alignment line.
If you have a top surface, then need to select that surface while creating a pipe network, so that the structure cover will exactly on that surface levels. If you wanted to show pipe network profile, not on the road, then its better to create alignment from network and then create profile.
Regards
Message 8 of 11
Dear @Sinoj.Ravindran
I am already creating pipe network by giving it surface of road but its not coming on the same level.
Message 9 of 11
doben
Is your reference surface 12-STREET-03 created from your corridor (top surface)? Sounds like it is a datum surface.
In the Structure Properties window you can override the rim elevation by entering 0.5 in the Surface Adjustment Value
Message 10 of 11
Dear @doben
Yes it is my corridor surface,
Is there any other way through which it can be adjusted on all the structures of the network?
like any rule or something else?
Message 11 of 11
doben
If it is your corridor surface (top links) then you shouldn't have to adjust anything.
I don't believe there are any rules to adjust this. An expression can be used in the structure label style (e.g.  {Surface Elevation at Insertion Point} +.5) although it won't physically move the rim.
