Pipe Network Profile to Outer Edge of Manhole
LarryS23
Message 1 of 18
LarryS23
I am trying to show the pipes attaching to the outer edge of the manhole. I have one that does it correctly and then another pipe that continues to the centerline of the manhole. It says that the pipe is connected to the manhole.
Replies (17)
Message 2 of 18
JRitner
Edit Structure Style > Profile > Enable Part Masking
Joel Ritner
C3D Certified Professional
BIM/Systems Manager
Najarian Associates, NJ
Message 3 of 18
LarryS23
I did that but still no luck.
Message 4 of 18
JRitner
Is your structure also set to Display as Boundary? (Looks like it is, but didn't want to assume)
Joel Ritner
BIM/Systems Manager
Message 5 of 18
LarryS23
It’s displayed as a block. Is that the issue?
Message 6 of 18
JRitner
It may be. One way to find out...
Joel Ritner
BIM/Systems Manager
Message 7 of 18
LarryS23
So I tried both displaying the structure as a block and as a boundary with the enable part masking and am still running into the same issue.
Update: So I think the issue is that the start structure is at 3 and there is no said end structure listed. Trying to connect the parts, but I thought I already did that.
Message 8 of 18
JRitner
Can you share your dwg?
Joel Ritner
BIM/Systems Manager
Message 9 of 18
LarryS23
Is there a quick way to fix this manually?
Message 10 of 18
sfore
what is your pipe rules set to for start/end location?
Message 11 of 18
LarryS23
Right now I am using the no pipe rules set
Message 12 of 18
LarryS23
Here is the attached dwg. I placed a box around the area where I am working in.
Message 13 of 18
jmayo-EE
I would try swapping the pipe out for a new one and see if that fixes the issue.
John Mayo
Message 14 of 18
JRitner
Pipe P2 is not connected to the manhole. Use the grip to pull it away then reconnect. Double-check your pipe inverts & you're good to go.
Joel Ritner
BIM/Systems Manager
Message 15 of 18
LarryS23
Hmm I found that if I move the pipe to the edge of the manhole and then back to the center, it just automatically joins the structure and so now my part masking is working properly because the pipe geometry shows an end and start structure connection.
Message 16 of 18
LarryS23
Is it good practice to lay out pipe network by selecting objects because the issue I run into was that I can only select one object at a time
Message 17 of 18
JRitner
I don't typically do it that way, but that doesn't mean it's a bad practice. Usually I determine structure locations as necessary and use Pipe Network Creation Tools to lay it out.
Joel Ritner
BIM/Systems Manager
Message 18 of 18
sfore
I don't lay out by selecting objects such as a polyline. I do layout by selecting the pipes and structures I want, then start placing with upslope toggled so that my structures and pipes start at 1 at low end. Then I create an alignment/profile by selecting start structure and end structure. If the pipes are connected to the structures, the whole line will highlight. Also, by doing it this way, it only picks those pipes and structures (automatically) to throw in profile. I use the Pipe Network Tools to quickly change reference alignment.
Note, my pipe rules are set to structure center initially so that alignment vertices are created at center (insertion) of structure. Then I change end location to structure inner wall and apply rules so that I get a true pipe length.
