Pipe network parts list missing
jricha5
jricha5
I am trying to access certain part lists in drawing 1, but the network parts lists are not showing up. In drawing 2 the parts list are showing. Both drawings are referencing the same catalog folder, so what else could be different between the two drawings that is causing this issue?
Drawing 1
Drawing 2
brian.strandberg
Parts lists are saved just like styles in each drawing.  I would open both drawings and drag and drop the part list into the drawing without it.
Alternatively you can use the import styles and settings from the manage tab to import that.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
jricha5
Thanks, i forgot I could drag and drop parts lists just like styles, this has fixed my issue!
