PIPE NETWORK - LABELS
F.Camargo
Advisor Advisor
F.Camargo
Guys,
I'm trying to insert 2 kind of labels.
First label is of the station profile, into the structure label.
Second label is just calculate the slope in meter per meter.
I'm trying to create a expression, but I can't find "insert rim elevation"and "sump elevation" in the pipe label.
So I've calculated with pipe (slope/100) but couldn't hide % symbol.
Thank in advance
Civil3DReminders_com
Assign the alignment in the structure properties and then use the alignment station in the label. You can override the alignment to the alignment profile if you need them to be different.
In the label text component change the format from % to the decimal one.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
F.Camargo
Thank you very much!!!
I'm really happy 🙂
