Is there any way to disable the Pipe Deflection (Not the graphic symbol) in the Pipe Only Mode?
AutoCAD assumes that contractors have installed the existing pipes base on the manufactures specs or their design guides........Right!!
What I am trying to do is use the "Pipe Only" mode to follow the utility line where the surveyor has indicated the location of the line is.
VRS 2015 in Use.
Dave Z.
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
Please select "accept solution" so other readers may be aware of your solution
Joe Bouza
