Pipe data in the profile view data band
Hello
I would like to inquire if there is a way of ensuring that pipe data in the profile view data band only appears when there is a change in pipe characteristics rather than after every manhole.
I do have different manhole spacings in my project ranging from 5m to 100m. I would like pipe data, including the pipe material (e.g PVC) and diameter (e.g 200mm) to be displayed in the pipe data profile band. However for small manhole spacings like 5 or 10m, this data (e.g 200 mm PVC Pipe) is too long to fit within the given extents and as such overlaps as shown in screenshot 1.
Is it possible to have a single text cover a range of spacings with the same pipe data and descriptions, and only have them change when an attribute say pipe material changes as shown in screenshot 2.
Ps. The drawing in screenshot 2 was altered manually in autocad after exploding
Thank You
Justin B.
Civil Engineer and Autodesk user
chriscowgill7373
I dont know if there is a way to guarantee it, but you could try a couple things, turn on weeding. or use CTRL when selecting objects to delete them individually.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Thank you for your response. I will give it a try and see if it helps.
Justin B
