Perpendicular curb ramp
aylinlopez25601035
aylinlopez25601035
Good afternoon, not sure if this is a topic someone already asked about it.
Do you guys know what's the best workflow to design a perpendicular curb ramp:
I attached two pictures, the first one is using a curb return as baseline and 2 feature lines for one quadrant of the turnout, the second one is using the curb return as a baseline (c&g and existing edge) and target this into the alignment and the edge of pavement (feature line)
pic1
picture1picture1
pic2
pic2pic2
And probably the first or second option will depend on how water runs, i may have to redo the whole turnout for a proper drainage.
Aylin
fcernst
Right..priorities.. fix the drainage first.. create the minimum or better required invert to work with .. then work it out.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
ecfernandez
Hi @aylinlopez25601035, I'd go with option 2. It seems to mee it can be easier to control elevations.
Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
aylinlopez25601035
Yes, 2nd option is the better option.
