PDF TO LINEWORK
PDF TO LINEWORK
bnagel
Message 1 of 22
PDF TO LINEWORK
bnagel
Any suggestions on a program that converts PDF to linework? I have a lot of contour lines I need to create for surfaces.
Replies (21)
Message 2 of 22
Jay_B
AnyDWG has a converter, I haven't used the pdf to dwg converter, but used their dwf to dwg converter and was very impressed with the results.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 22
Todd_Rogers
2017 has this option built in, PDFIMPORT. If you don't have 2017, the best one out there is PrintToCAD. http://www.backtocad.com/engl/engl-pdf-to-dwg-lp.html
Todd Rogers
Civil Administration
Message 4 of 22
bnagel
I've been debating on when to make the move to 2017. Have the bugs been worked out?
Message 5 of 22
Todd_Rogers
Well that's kind of a loaded question. There is an SP1 out for C3D and AutoCAD. However, it seems that the service packs break other functionality. Go figure.
Todd Rogers
Message 6 of 22
neilyj666
The bugs will never be fully worked out......!!!
The 2017 pdf import works well for me but if you don't want to make the leap just install Vanilla AutoCAD 2017 to convert your pdfs and then insert them as blocks into Civil
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 22
bnagel
Will my settings from 2016 transfer over to 2017?
Message 8 of 22
civilman1957
"The bugs will never be fully worked out......!!!"
Truer words have never been spoken, my friend...
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 9 of 22
Jay_B
Not to discourage you from upgrading, but in case you aren't aware, Civil 3D 2017 is not backward compatible with any prior releases.
I Agree with @neilyj666 that 2017 AutoCAD might be your best option if you chose not to upgrade at this time.
AutoCAD 2017 is still uses the 2013 dwg file format & doesn't have the backward compatibility issues Civil 3d does.
C3D 2018.1
C3D 2016 SP4
Message 10 of 22
neilyj666
Yes just install vanilla AutoCAD and use the PDFIMPORT command to make a block of the PDF and Save. Then simply insert into a Civil dwg and scale/rotate as required.
This is the workflow I used until I moved fully moved over to Civil 2017
Message 11 of 22
bnagel
How or where do I find/install vanilla Autocad?
Message 13 of 22
AllenJessup
I didn't have high hopes but I brought in a rough PDF to try it on. It worked surprisingly well. Thanks.
Allen Jessup
CAD Manager - Designer
Message 14 of 22
Joe-Bouza
Maybe not obvious to all, but know that they only work with a vector to raster pdf. if it is scanned it probably wont work
Joe Bouza
Message 15 of 22
tcorey
Yes, if the file has been scanned, save it as TIF and then use Raster Design to vectorize semi-automatically.
@Anonymous (bill?) Do you have Infrastructure Design Suite or just Civil 3D?
If you are the bnagel I know personally, feel free to phone me, 530.221.2994, if you are not able to find a solution from this thread.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 16 of 22
bnagel
My name is Bobby, I only have Civil 3d
Message 17 of 22
Todd_Rogers
Go to your programs and you will see run AutoCAD Civil 3D as AutoCAD.
Todd Rogers
Message 18 of 22
AllenJessup
Joe, You're right. I thought the one I tested was scanned (and the basemap is) but vector information was added. Did work well though.
Allen Jessup
Message 19 of 22
bnagel
Sorry but, I'm not seeing it.
Message 20 of 22
bnagel
Found it.
