- Mute
- Permalink
- Report
I am currently tasked with creating some new manholes in part builder for a project my company is working on. The manholes we will be working with are essentially the same as the built-in Rectangular Structure Slab Top Rectangular Frame manhole found in the Junction Structure with Frames catalog. I was able to easily use this manhole to add in new size parameters that we will be using for our project. The only outlying issue is that the insertion point for the built-in manhole is currently at the center of the part. Our project has manholes that are wide, and the pipes that tie into them enter the manhole off-center. Is there a way to do a save-as of this part and update the autolayout data so that the insertion point of the manhole is not the center of the manhole. I am fairly new to part builder. Any help is appreciated!
See the attached image for a plan view snap of one manhole and utilidor piping example. The yellow manhole and utilidor are what I have added in as a pipe network. The green manhole that can be seen behind the yellow manhole is an reference showing where the yellow pipe network manhole should actually be located. As can be seen, the yellow utilidor does not need to move, but the manhole needs to be placed slightly off center.
