Hi @meel1986,
Welcome to the forum, and thank you for posting. I agree with @EBDBC3D, @tcorey and @m_kingdon, you can grade parking lot using a combination of feature lines, corridors, and grading objects. @m_kingdon, had provided detailed step by step on this workflow as shown. Do check it out.
I will go ahead and mark Mike's post as a possible answer. This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu > Not the Solution to cancel an accepted answer.
