Parking Lot Design / Grading Workflow
meel1986
Observer Observer
Message 1 of 8
meel1986
Observer
Observer
How should I handle this parking lot design? Should I run four different Center line alignments (shown as red,blue, yellow lines) then just build assembly for a full road section and a separate assembly curbs for the islands? How should I handle the grading, through grading objects?
Replies (7)
Message 2 of 8
Elina.P
Autodesk Support
Autodesk Support
Hi @meel1986!
I would suggest using the Vehicle Tracking extension for Civil 3D, where you can create parking lots and also create later grading from them automatically.
Give it try and let me know if it works for you!
Elina P.
Technical Support Specialist
Civil Engineering Solutions
Message 3 of 8
EBDBC3D
I'd use feature lines and gradings. Corridors for parking lots is crazy to me.
Message 4 of 8
tcorey
Corridors can whip out those curb islands very quickly and you can use grading infill for the rest of the lot.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 5 of 8
meel1986
Observer
Observer
What would you suggest the workflow to be? Should I run corridor along the curb lines (which are utilized as alignments along ETW) then grade inside? I have drainage in the middle of the roads, can I invert the road CL assembly and match the curb lines to the ETW? How should I handle the little island if I run the full road section and target the curb line (shown in the attached picture)?
Message 6 of 8
m_kingdon
This was one of the Civil 3D forum challenges posted a few months ago. Check out this topic for some workflow ideas.
https://forums.autodesk.com/t5/civil-3d-challenge/c3dchallenge-3-grading-parking-lot-may-16-may-28/t...
Mike Kingdon
Civil 3D Zealot
Message 7 of 8
lim.wendy
Hi @meel1986,
Welcome to the forum, and thank you for posting. I agree with @EBDBC3D@tcorey and @m_kingdon, you can grade parking lot using a combination of feature lines, corridors, and grading objects. @m_kingdon, had provided detailed step by step on this workflow as shown. Do check it out.
I will go ahead and mark Mike's post as a possible answer. This won't prevent other folks from commenting on this question though, in the event other ideas come up!
Remember to mark your posts as having an "Accepted Solution" if a solution is found as it helps other forum users with the same issue – so don't be shy about marking it as a solution! Accepted solutions get viewed more and help more users find the answer to their problems. . You could unmark the post as an accepted solution if the solution did not work. Click the ellipsis menu  > Not the Solution to cancel an accepted answer.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 8 of 8
nveselyR6DU4
Personally, I like using the alignment/profiles and offset alignment/profiles to generate a really simple corridor representing asphalt surface and then using that simple surface as a reference to generate the curb lines.  All curb lines are then just modeled as 2 feature lines, one at bottom of curb and top of curb which have automatic reference elevations from the base surface.  Then all feature lines (and therefore curb lines) adjust automatically by making edits to the corridor base surface.
