Civil 3D Forum
Paper space objects keep going under wipeout
5 REPLIES 5
1248 Views, 5 Replies
I have a drawing with a couple objects in paper space in the layouts that I put a wipeout behind (also in paper space). I did draworder and sent the wipeout to the back so the objects would be on top of it. I have this in several tabs.
Every time I close the drawing and reopen it, the objects are UNDER the wipeout. I've fixed this with draworder 3 times now and it keeps doing it again every time I close the drawing and reopen it. Is there some way to fix this?
5 REPLIES 5
AdammReilly
There are similar issues with draw order being retaining inside blocks.
My work around is usually to copy the object I want above the wipeout and delete the original.
Adam Reilly
Dell Precision 55400
Windows 10 Pro
Intel Xeon E-2276M 2.80GHz, 64bit
NVidia Quadro T2000 Mobile/Max-Q
LinkedIn | Twitter
Group Leader badge
Austin CADD User Group
LinkedIn | Discord
in reply to: AdammReilly
So how do you do that? Bring it to the front then copy and paste?
AdammReilly
Just use the copy command. All new entities are put at the top of the draw order stack, so it's automatically brought above your wipeout. Once you copy it, delete the original object.
Adam Reilly
Windows 10 Pro
LinkedIn | Twitter
Group Leader badge
LinkedIn | Discord
wfberry
The point is that the copy is newer, thus it will be on top.
Bill
samir_rezk
if you are using Civil 3d (Not vanilla AutoCAD!) assign the wipeout a layer that is different from the text layer and configure the layer order by using the “layerorder” command to ensure the text layer takes precedence over the wipeout layer.
hope this helps,
Samir Rezk
Technical Support Specialist
Rail Community
