When a model becomes slow or seems to be having an issue, I use the Audit command to see if any errors have occurred and for it to fix it.
However, perhaps this is due to my company's settings of the template file, but the Audit command always seems to get stuck at "Audit Pass 1 114000 objects audited". It shouldn't take fifteen minutes to get a reply that either "no errors found" or "2 errors found".
Like, is it possible to speed up the process? The model I'm in right now only has a bunch of multileaders, text and xref of 2D objects and still the process takes forever.
