Optimize audit command
Ingrid91
Ingrid91
When a model becomes slow or seems to be having an issue, I use the Audit command to see if any errors have occurred and for it to fix it.
However, perhaps this is due to my company's settings of the template file, but the Audit command always seems to get stuck at "Audit Pass 1   114000    objects audited". It shouldn't take fifteen minutes to get a reply that either "no errors found" or "2 errors found".
Like, is it possible to speed up the process? The model I'm in right now only has a bunch of multileaders, text and xref of 2D objects and still the process takes forever.
ianjchap
Hi @Ingrid91,
Two things come to mind on this. First, you could run a Recover command on opening. In the command line of a blank drawing, type recover then choose the drawing you want. This pretty much opens via an Audit routine and may speed things up.
Also, you can do a deep purge (-purge), this will allow selected items, but also give you the option to remove Regapps which often cause speed issues.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Joe-Bouza
Try
_PU R ALL N
again until none on command line. I suspect you have thousands.
then audit.
if there xrefs involved you may want to go through them first and the regg adds from xrefs do pollute the host
Joe Bouza
