Online Maps
Online Maps
brooke_stephens
Message 1 of 18
Online Maps
brooke_stephens
I am unable to visualize Online Maps.
I am logged into Autodesk account, I have set units and Coord System, I have toggled Map Aerial/Map Off, I have tried zoom in/out, zoom extents, regen, I have accepted Yes to use of Online Maps.
Is there anything else I can try?
Replies (17)
Message 2 of 18
Pointdump
Hi @brooke_stephens,
Welcome to the Autodesk Forums.
Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 18
brooke_stephens
Attached is Access Exhibit - Module 2 Working.dwg  This particular dwg is for a class assisgnment.
Message 4 of 18
Pointdump
Bing Live Maps immediately came up when I opened your drawing. So if it doesn't on your end, I guess it's a network permissions thing. Are you on your home computer?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 18
brooke_stephens
I am working from home, using a work computer with a network license.
Message 6 of 18
Pointdump
Any Firewall or Anti-Virus programs on?
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 18
ChicagoLooper
Hi @brooke_stephens
AutoCAD can be finicky.
Shut down and reboot.
Chicagolooper
Message 8 of 18
brooke_stephens
Firewall, Anti-Virus, and browser settings are all controlled by an administrator for my work laptop - I have contacted IT to see if they could do anything on their end for the above noted and for the Civil3D permissions and license.
.... I'm still checking other avenues though.
Message 9 of 18
brooke_stephens
I've been trying to figure this out over a week, over that time I've shutdown/restarted the program, the computer, and went through computer updates, as well dumped and redownloaded this above dwg, starting new dwgs, and going through other dwgs of current projects.
I'd been hoping it would be a simple toggle or reboot solution.
Message 10 of 18
AllenJessup
You can go through the steps HERE. I don't know if that will solve the problem.
Allen Jessup
CAD Manager - Designer
Message 11 of 18
ChicagoLooper
<<...I am logged into Autodesk account, I have set units and Coord System, I have toggled Map Aerial/Map Off, I have tried zoom in/out, zoom extents, regen, I have accepted Yes to use of Online Maps....>>
Try to re-establish your choice to use Online Map Data.
Options=>System tab=>General Options=>Hidden Message Settings=>check box labeled Geographic Location
Use Online Map Data? Choose yes.
Chicagolooper
Message 12 of 18
brooke_stephens
Thank you for the detailed instructions.  When I learned about that last night I was hoping that would be my fix, I did need to check those boxes, but the imagery still won't visualize, nor does Bing show in the lower right of the model screen.
Message 13 of 18
brooke_stephens
Thank you all for the help!  The problem was found in the VPN I was using.
Message 14 of 18
mford515151
Observer
Observer
geomap was working yesterday, windows 10 updated itself today, now geomap is NOT working. says I don't have permission.
Message 15 of 18
ChicagoLooper
Hello @mford515151
I've seen that happen too often. Close the drawing and reopen it. Even though it says you don't have permission you do. The program doesn't have the option of describing the issue in another way so it defaults to you don't have permission.
Chicagolooper
Message 16 of 18
ChicagoLooper
duplicate post.
Chicagolooper
Message 17 of 18
brooke_stephens
The problem was discovered - it was the VPN server I was using for work.
Message 18 of 18
30001167
Happened to me also, resolved by switching off my VPN. Thanks!
