Offset Points
Offset Points
redasobeh
Message 1 of 12
Offset Points
redasobeh
I have a group of points (enz), and i need to offset it all,
How i can do that?🤔
Thanks All.
File Attached.
Replies (11)
Message 2 of 12
Pointdump
Hi Reda,
Offset which way, X,Y,or Z?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 12
redasobeh
I need to offset it all (xyz) to Left or Right like a Line with a specified Distance..
Message 4 of 12
Joe-Bouza
Run a feature line through the nodes >> offset h&v>> write new point along FL
Joe Bouza
Message 5 of 12
redasobeh
could you give more explanation, please?
Thank You.
Message 6 of 12
Joe-Bouza
Assuming these point are civil3d cogo or are point with elevation
snap a feature line to the nodes >>> use FL offset tool for distance/ (grade / difference)
then add cogo point >>> along FL
now you have points offset and change z
This is one way
another: station offset report to excel >>> change offset and z
then import by sta offset
Joe Bouza
Message 7 of 12
tcorey
You can use AutoCAD Move command or Copy command to move those a certain distance and direction.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 12
redasobeh
I will try it.
thanks so much.
Message 9 of 12
redasobeh
But there are two Curves I have in the Path of that points,
I need to offset every point perpendicular to the path.
Message 10 of 12
Joe-Bouza
Are the point on this path? that will be you FL otherwise alignment ... how about a picture and maybe a file
Joe Bouza
Message 11 of 12
redasobeh
File attached,
Message 12 of 12
Pointdump
Reda,
"...there are two Curves I have in the Path of that points..."
The suggestion by @Joe-Bouza of running a Feature Line through the points will probably be your best workflow, but first you need to decide where the curves start, and check tangency of the lines, if that's important. Also, you have 2 regular curves and 1 reverse curve, so that needs to be taken into account.
Dave
Dave Stoll
Las Vegas, Nevada
