Offset Assembly
Offset Assembly
akbar.ghav
Offset Assembly
akbar.ghav
I tried this but I am having some problems.
There are two alignments, one for the main road and one for the bike lane.
Both are passing over a bridge at some points but otherwise they follow two different alignments.
Why does the bike Lane stop at that point right of the bridge? I would like to contunie the Bike lane to the end of the alignment .
 The other problem is that the bike lane does not go pass the main road left of the bridge.
tcoreyKM7TG
Don't use Offset Assembly. Make one especially for the Bike Path and make the Bike path its own Baseline within the Corridor. It can target feature lines created in the Road baseline regions if you need.
The reason the bike path is not finishing, is that you get to a point where an offset assembly can't intersect it properly. See where your bike path curves away from centerline at a severe angle? That causes it to need to go down-station in relation to the centerline and that doesn't work.
