Odd grading triangles top left pad
PeterKozub
PeterKozub
Hi
Notice odd triangles top left
labeling feature lines with grade dist and end points work well
with grading editor
Any ideas on the triangulation
Thanks Pete
Play attached Mp4
Xi Computer S/N: 037019
Intel Core i7-2600K CPU @ 3.40GHZ
Mem 24.0 GB
Win 7 64.0 Bit
12 Gig Video Card Nvidia K6000
2 4k Monitors
Autodesk C3D 2016 subscription Service pack 3
HP T120 Roll feed 24" plotter.
wfberry
Not sure what caused that problem.  However, if you mark one corner where you have it, move it away and back again it FIXES itself.
Bill
PeterKozub
Hi Bill
I did what you suggested and it worked sort of
Also note the text is auto dragged suggesting that there is
some sort of hidden edit history being applyed ?  this
drag edit was done many steps earlier and shows
up like a
note slope indicators are cleaned up also
I placed a yellow line at feature vertex and drag it away and then back in two separate steps
and the odd triangles and slope indicators reappeared...
The short 2.88 segment indicates a start point for some investigation by programmers
Pete
tcorey
Fillet the corner of the building pad.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
PeterKozub
Hi Tim
Tried what your suggested and it did help the corner triangles
the top left short segments rogue triangles still linger please zoom in on attached DWG and
you can see them.
Also the slope indicators are still overlapping
The best thing about this little DWG is that its small enough that programming types can
hopefully find it.
Would not like to find this behavior in a large grading job hours could go lost...
see attached PNG and DWG
Pete
tcorey
Peter, add some elevation points in that area. Select the feature line on the screen and then:
Does this look better?
Tim Corey
Redding, CA
