not sure if i understood your method, please see my questions below:
for slope analysis, i'd probably use the built in surface style for slope analysis.
that's what i used, i have the surface set up in 2-D slope banding. but the slope for the banding is in ranges, i need the point slope. also, i cannot think of a way to even extract information from those slope banding solids into the cogo points.
If you must use the specific points you already have, then i'd probably place a 1 pt surface label on each one which would tell me the slope at each point. then i'd probably edit the point description or some other point data field to indicate the slope. then the points could be exported to a text file and imported to a spreadsheet.
not sure i understand. i think you are suggesting setting up 1-point slope labels on the nodes of all the cogo points, then manually edit the cogo pts description and hand type the slopes in? i would like not to go that route, i have >7000 cogo points.
you know (plz dont take it the wrong way, i am not comparing capabilities of softwares here), arcmap has a tool that extracts raster values and joins to the attribute table of an overlaying points layer. is there anything similar in Civil 3D?
