If you want to turn off the visibility of Layer "0" this layer must not be the current layer.
Obviously you (or whoever or whatever 😉 ) disabled the view of this warning message:
[EDIT]: Perhaps set the system variable EXPERT to 1 will help to see this message(?)
After you set an other layer to be the current one, you will get what you expect.
If this doesn't solve your problem, tell us which objects are the problematic. (I had to do a long search until I found a symbol where the problem occurs).
" ... it says it was on layer "0". But on the the properties it was on the right layer." doesn't make sense for me. I found 15 block references on Layer "0". Is that the "right layer"?
Jürgen Palme
