Object Data query causes internal error
Message 1 of 1
We are working in the Planning and Analysis workspace (AutoCAD Map) of Civil 3D.
The file we are querying has closed polygons with object data attached to them. the polygons were created by cleaning polylines, then creating topology, then creating closed polygons. An object data table was created then attached to the polygons. The records were then edited to add a county name. This was saved as  source file and closed. A new file was created and the source file is attached as a source file in the Map Manager tab of the taskpane. A query was created to redraw the polygon with a coloured hatch. The query was saved in a query library then run causing an Internal error.
Replies (0)
