Both Null Structures and Inlet/Outlet type structures still report an Insertion Rim Elevation in tables and labels. Is there a way to automatically determine structure type and have it set rim elevation to 0.00 or report NA?
Technically, a null structure does not have any rim data, that variable is missing from the definition and does not show up on the structure properties to even change.
Even worse, when listed in the panorama, you can type in another elevation, but it never accepts the new elevation after you hit enter.
I tried an expression:
IF({Insertion Rim Elevation}>100,{Insertion Rim Elevation},0)
This worked partially, however, the headwalls still grab a random insertion rim elevation above 100, therefore it doesn't work. The same happens to any null structure that has more than 1 pipe connected to it.
I'm very frustrated, and tired of using wipeouts to mask the rim elevations for these structures, then double check if names change or additional structures are added to the system.
