Daer People,
I made a cut assembly by 'Subassembly Composer 2018'.
It contains each link and point codes.
But, it does not appear when I import to C3D (please find the attachments).
What is the problem?
Please share any idea 🙂
Thanks and Regards,
Solved by taophatxit. Go to Solution.
you are working at "Roadway mode" - (you can see it in preview box in Autodesk Subassembly Composer)
change it to "layout mode" you will see how it show in Civil 3d (at your image attch "C3D.PNG") .
To correct it, you can set data for layout mode (see it in my attach).
Roadway mode : it mean how to it show in corridor (subassembly have things taget, offset)
Layout mode: it mean how to it show when you creat assembly
:))) as far as i know :))
Thank you for your reply 😉
1 more question.
Should I attach any sequence in red boxes?
Is it essential?
i think you should make a report error (in my attach - red box) to make used know it wrong
