Not able to import my CSV file in civil 3d
ce21b020APBPZ
ce21b020APBPZ
I saved my data in .csv format from excel. It looks like it's formatted correctly but, when I Import Points from the file into Civil 3D, it keeps telling me "No point file format match found". It should be a standard PNEZD Comma Delimited format. I have checked the csv file in excel and notepad looking for errors, but it looks fine. I'm uploading the csv file here if anyone can find what`s wrong.
Accepted solutions (3)
Replies (13)
Pointdump
Hi Kalyan,
You have 7 columns of data. After creating 2 User Defined Properties you'll need to create a custom point file format, maybe something like Name,Northing,Easting,Elevation,UDP Start Depth,UDP End Depth,Description. And at the first of line 1 of your CSV add "#" so that line will be ignored on import.
Drawing and CSV attached so you can see how to set up User Defined Properties and the custom Point File Format.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
ce21b020APBPZ
Thank you so much for the reply and solution sir. And thankyou for sending the corrected files.
ce21b020APBPZ
Sir I tried as you said. But, again it's not working. Can you check that?
I'm sending the image.
Pointdump
Hi Kalyan,
Did you add "#" to the beginning of the first line of your CSV? That comment tag tells Civil 3D to ignore the first line. You can also just delete the first line, but I like to keep it, as it describes your data.
Use the Load and Parse buttons to check the Point File Format. Send another screen shot if that doesn't work.
Dave
Dave Stoll
Las Vegas, Nevada
ce21b020APBPZ
Sir, I used # and I also used the file that you have sent. I also used load and parse too. After clicking Ok, it's there in the filters but it's not accepting the csv file.
Pointdump
Kalyan,
Screen shot please of where things go wrong. A video would help.
Dave
Dave Stoll
Las Vegas, Nevada
ce21b020APBPZ
Sorry sir for late reply. I have some college submissions. Maybe the way I import is wrong. If you don't mind, can you send me a video of importing properly?
Thanking you.
ce21b020APBPZ
Sorry sir, for late reply. Once check this video.
Thank you.
Pointdump
Kalyan,
Thanks for the video.
You did everything right creating the User Defined Properties and the custom Point File Format. Try saving the drawing, closing, then re-opening.
Edit: Post your latest drawing and I can check it.
Dave
Dave Stoll
Las Vegas, Nevada
ce21b020APBPZ
I tried again sir. Now it's working.
Thank you so much sir.
ce21b020APBPZ
Sir, can you help me with creating and visualizing the strata surfaces with the borehole data in Civil 3D?
Pointdump
Kalyan,
Good to hear it's working now for you.
For the borehole strata, you'll want to post a separate question on that. I haven't much used the Geotechnical Module, but several people on this forum have.
Dave
Dave Stoll
Las Vegas, Nevada
ce21b020APBPZ
Thank you so much for the help sir.
