- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
From the Civil 3D tabs, I go to insert, points from file, and select said csv file. Once i select the file it says that no point file format macth found. I have checked the csv file in excel and nopepad looking for errors, but have found none. This particular csv file is from a topo i did of a site on a Trimble TSC3 data collector. I exported the measured data (the points) to a CSV file with the file format as PNEZD(comma delimited). We then synced the data collector with the computer and loaded the file, going into excel and cleaning up all the headings and unused data not needed and saving only the PNEZD info. We had a problem with this one time and figured it out to where it worked right. I thought it was something in excel we need to change but i cannot remember what we did and cannot figure it out after messing with it. Has anyone else had this problem before? Any help would be great! Thanks!
