No Elevation When Hovering Over a Surface
Message 1 of 13
I have created a surface, when I hover over a contour on it I used to get name,style, layer, elevation.  Now I get them all except elevation, I didn't change anything (not on purpose at least) in my drawings does any one know of a reason for this?
Replies (12)
Message 2 of 13
sboon
Open the Properties dialog for your surface and check that the Tooltip option is turned on.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 3 of 13
Neilw_05
Open the Civil 3D surface properties dialogue (not the Autocad Properties pallete). On the lower left corner of the Information tab there is a toggle Show Tool tips. Make sure that is on.
If it is then you'll need to check your global settings for the file and for your Civil 3D user profile or workspace.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 4 of 13
RandyBenson
I've got no elevations when hovering over my surface either. The tooltip option is turned on in surface properties and in options-display-show rollover Tool Tips. It is set in my profile. Still no elevations. Anything else I can try?
Message 5 of 13
RandyBenson
Whatever is going on is drawing-specific. I have other drawings that I can open simultaneously with this one where the elevations do display on hover.
Message 6 of 13
troma
Check what layers are frozen. I think you need to have the surface layer thawed (probably C-TOPO, but try others too).
Mark Green
Working on Civil 3D in Canada
Message 7 of 13
RandyBenson
I could've sworn I checked frozen layers, but yeah, turning V-TOPO on did the trick.
Message 8 of 13
dbinkney
Thanks, I have been looking up how to turn those elevation hovers off since I so many surfaces loaded it was slowing things down
Message 9 of 13
In addition the the settings mentioned in other comments, I also had to DRAWORDER my surface to the front.
Message 10 of 13
jmayo-EE
Ah yes, the beauty of the NCS template. No layer control for your surface (try IsolateLayer) but you still need to manage two layers. Even more when you add labels. Twice the work for half the function!
He facetiously said...
John Mayo
Message 11 of 13
kevin
SHOWCT is the command I forgot....
Message 12 of 13
Mehdi_Rostami
I found this setting was off for me, turned on and then I have surface tooltips displayed again. To get there go to Settings>Right click the Drawing Name>Select Edit Drawing Settings. Then go to Ambient Settings>General>Show Tooltips
Message 13 of 13
Eddie_SmithZ792N
Community Visitor
Community Visitor
Thanks Mark! This solved problem for me.
