new contours will not go straight
Message 1 of 9
I have a new surface made from a corridor and they are not straight across the road. my road has a 2% cross slope. I can only get straight lines if I do a 0% cross slope.
Replies (8)
Message 2 of 9
rkmcswain
Turn on your triangles and see what is going on.
Contour lines are simply connecting like elevations on the triangles. Bad triangles will give you bad contours.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
How do you know you have bad triangles and how would you fix them?
Aren't the triangles made from the contours?
Message 4 of 9
Todd_Rogers
Depending on which surface you used (top or bottom (datum)), you need to apply Overhang Correction. If the Top, then Top Links. If the Datum, then Bottom Links...
Todd Rogers
Civil Administration
Message 5 of 9
Joe-Bouza
NO
The elevation data you feed the surface is "Triangulated" . The contours are interpolated along the triangles.
TIN= Triangulated Irregular Network
Joe Bouza
Message 6 of 9
Joe-Bouza
The contours are the visible expression of the triangles if they look bad doesn't really mean the triangle are. You need to compare your data with the results.
Also, what other possible data is in the definition.
Occasionally triangle may not go where you wish due to conflicts in data: missing feature line, blown elevation, wrong links used in corr surf, data you did not intend to add to the definition....
Joe Bouza
Message 7 of 9
doni49
Based on the limited info we have so far, my first thought is that under the surface tab in the corridor properties, you haven't turned on use as breaklines.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 8 of 9
wfberry
NO!  If you ever had the "opportunity" to draw contours by hand it would help your thinking.
Do this--> take a handful of points and plot them out.  Draw lines between each point and see they end up being triangles.  Calculate where the EVEN contour will pass through these lines and you can see why they are not straight.
Bill
Message 9 of 9
BrianHailey
My first guess is you've added too much data to your surface. What links/featurelines did you add from your corridor to the surface?
Remember, a surface can't have more than one elevation at any point. This means at the edge of asphalt, you can't have a surface that has the elevation of the edge of asphalt and one for the base course at the edge of asphalt.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
