home tab / create design / create network parts list
I created a new parts list but when I go to another .dwg file it doesn't show up under the network parts list.
Solved by JeffPaulsen. Go to Solution.
You can drag and drop the parts list from one drawing to another in the same way you would a style.
where do I drag it from?
I don't see it under toolspace/settings
Toolspace > Settings > Pipe Network > Parts Lists
If you are very fond of your part list, you may want to drag and drop it into your startup.dwt file
Joe Bouza
