Civil 3D Forum
.Net Sub Assembly Error
8 REPLIES 8
Message 1 of 9
5188 Views, 8 Replies
the error message I am getting:
"Macro file not found at original path specified in subassembly.  Updated macro file location to path defined by AECCCONTENT_DIR environment variable.  (Source: C:\ProgramData\Autodesk\C3D 2011\enu\\C3DStockSubassemblies.dll!Subassembly.BasicShoulder)    ©ÖMM  "
This started about a week ago after a MS Windows "security update".
I did a restore point back to a point before this update.  Did not fix
Went to the .Net website for MS and they had a "repair".  Did not fix
Did a "repair" on Autocad.  Did not fix
Did a reinstall of autocad. Did not fix
Did an upgrade to Win7 64 bit and Civil 3D 64Bit.  Did not fix
repeated the Win 7 and Civil3D install,  Did not fix
Tried to create a new drawing with subassemblies after the 32 bit install and the second 64 bit install.  Still getting the error through all of that.
I don't know what else to do....
8 REPLIES 8
Message 2 of 9
Jeff_M
Are you sure it is an error? This is normally an informational message when you first open a drawing with corridors in a newer version of C3D. The path to the subassembly .NET code is saved with the subs, so when the new version is found it gets changed to use the new path.
Jeff_M, also a frequent Swamper
Message 3 of 9
in reply to: Jeff_M
I am answering off my droidat the moment. Ihave a copy of the log file that shows all the errors. In addition to this, the is another error. I thought I included it. However, if I go into the subassembly and edit a parameter, it will not update to the drawing. That error code I forgot or missed including. I will need a bit of time to include it here.
Message 4 of 9
I have included the log file of the errors I am getting.
This is the one I get for any assembly I am trying to edit.
Source:     n,NM       Roadway    Jon {  []0+50.00':  .Net subassembly project, module, or class not found
Message 5 of 9
Jeff_M
Would it be possible to send me the drawing? miff AT sonic DOT net
Did you previously use any custom subassemblies?
Does this happen in just this drawing or many?
Message 6 of 9
in reply to: Jeff_M
I have two drawings (sent you both)
The subd_complete dwg is a file I have been using since Oct with Subassemblies.
the subgrade dwg I started with about 2 weeks ago.
This issue started this last weekend.
Thank you,
Jon
Message 7 of 9
Jeff_M
The subd_comp.dwg I only get the normal "macro file not found at original location. Updated to ...." It looks like this was last used on a PC using XP....in XP the DLL is located under Documents and Settings, but Vista/Win7 place it in the Program Data folder structure, therefor this is normal. There are some errors showing, but those are due to targets at the intersections....I did not investigate these, but I usually see this when the target for a width results in a 0, or negative, width subassembly.
The other drawing has a phantom Subassembly in the "Full" Assembly. It is named " - (84)", connects to the left edge of paving, and the 'out' point is towards the centerline. I'm n ot sure what this was supposed to be, but it is definitely what the Panorama is telling you it can't find. Deleting this subassembly, then rebuilding, removes all but 4 errors....again these are related to the intersction targets.
Hope that helps
Message 8 of 9
in reply to: Jeff_M
thank you.
Message 9 of 9
opesch_
Hello we've exactly the same problem after having done a fresh upgrade to SEVEN on our worksattions (HD were formated and linked in RAID0 and the Autodesk installation folder structure was completely revised to put all civil data, libraries & projects on a network drive)
I opened an old project whith some datashortcuts and 3 corridors, I've try to update one of the corridor with new profiles datashortcuts but CIVIL tells me that they are "no targets in the scripts",
once I right click on my assemblies to view they construction properties & codes, I always receive the same error msg :
"One or more subassembly macros (or .Net classes) could not be found. Check Event Viewer for more info"
when I see in the error vista, I can see that he's searching the C3DStockSubassemblies.dll in the old folder structure and obviously doesn't find it.... And I haven't seen where to set the new path in Civil (not found in option dialog !)
More problematic.... if I try to make a new assembly and I click on a subassembly on the tool palette he tels me the exactly same error as when I edit the corridor or try to see subassembly codes
It seems that the above dll catalog path is hard written in the DWG and doesn't depend on how was CIVIL instaled an configured !?!
Do you know how I can resolve this issue ? I send you my DWG as E-transmit ;o)
I thank you for the time it will take
Rail Community
