Negative cut and fill volumes using sample lines
I am creating volume reports using sample lines and computing materials. For some reason I am getting negative values for some of the volumes. Does anyone have a fix or explanation for this?
Does anyone know how civil 2016 calculates the volumes for each sample line?
-Kyle
Joe-Bouza
Reverse your base and compare surfaces
Joe Bouza
I dont believe thats the problem. The cumulative volumes im getting for cut and fill are close to what I find when I look at a volume surface comparing the two surfaces. Ex: Surface Volume Cut/Fill = 100/1000 and Sample line Volume Report Cut/Fill = 150/980
I believe it has something to do with the calculation method (I was using Average End-Area Method to calculate the materials). When I redo it using the prismoidal method for calculating the materials it no longer gives a negative value for those few fill sections. I just dont know why End-Area method gives negative values for fill in those sections.
Also, If I break use the fill areas and lengths between sections to calculate the volume using the average end-area method I get completely different results from what cad is spitting out. But if I do the same using the primoidal method I get the same answer that Cad gives using the prismoidal method. So I think Cad is doing something weird when it tries to use the average end area method.
neilyj666
You appear to have samples lines every 100' - the end area method assumes that the ground between sections is linearly varying and if it is not then there will be erroneous values compared to a straightforward surface to surface comparison which accounts for all the irregularities.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
