Need help guys :D Corridor
irakli.patsatsia93
irakli.patsatsia93
    Hi guys
When I split corridor and change the assambley   the corridor does not work.   I can not target surface.
    thank you for help
ecfernandez
Hi @irakli.patsatsia93, according to the video you are not clicking on the surface target options, but on the overridden station options. So you are getting that prompt because you don't have overridden stations.
Additionally, I am not sure if your assembly has those capabilities of targeting surfaces. You are using custom subassemblies and I could not check this to be 100% sure. Your assembly must have surface target capabilities so you can assign those to it. Are you willing to share your subassembly?
I hope this helps. Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
irakli.patsatsia93
         Thank you for your attention.  Your tips help me a lot.
 Here is my assembly.  I think it will be necessary to update the assembly.  I change codes.
irakli.patsatsia93
       I found it
  I am not clicking surface option:(((((((   I was sure that was a surface option  :D:((((   I need a little bit of sleep.
       thank you very very much.
irakli.patsatsia93
But I have know next question   😄 😄
    How to merge  bech and daylight top?
ecfernandez
Hi @irakli.patsatsia93, I opened your DWG file again and used your PKT file to be able to check if your custom subassembly has surface target capabilities and I found it is has them. Furthermore, your custom subassembly is targeting the surface on the left correctly.
So, in the end the problem was simply that you were clicking somewhere else. Nothing to feel bad about, it happens from time to time to all of us.
Best regards!
Camilo Fernández
LinkedIn
ecfernandez
I would say the quickest way to do that is to use Corridor Transitions. Edit the width of the bench and even the side slope if necessary, so you can get a smooth transition from normal slope to slope with benches. Pull the slope-bench region a bit back so your transition is developed before the original start of your slope-bench, the length of this transition should be suggested by your geotech team.
Regards!
Camilo Fernández
LinkedIn
