Civil 3D Forum
Need a help to plot corridor line into profile view and not the static I need it dynamic.
5 REPLIES 5
kamalgaramja556
280 Views, 5 Replies
Hello all, Thank you all in advance.
Now I am working on a tunnel corridor project, I have created my own subassembly, and using this I have created a corridor.  Now my problem is I want to plot the top and bottom lines of the tunnel section into my profile view and not the static I want it dynamic so if I change the corridor or profile then it also should be changed, if there is any method to do it please share with me. Here I have attached a picture of the scenario for more clarity.
Thank you !!
5 REPLIES 5
Hi there, creating two separate surfaces for those corridor links and then sampling them with your alignment might work, and it would be dynamic. Every time you make a change, you rebuild the corridor, then the surfaces get updated, and then the profile.
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
cwr001
in reply to: kamalgaramja556
Another way might be to just extract the corridor-featurelines for those points (make sure they are set to "dynamic" when extracting) and project them into your profile view.
Pros: Faster than creating surfaces.
Cons: You can't label them in your bands.
kamalgaramja556
in reply to: cwr001
But where is the option to make it dynamic.. can you share screen shot?
Thank you so much it work fine.. but it too langthy process.. anyway no problems thanks again.
Good to know it worked. Regards!
Camilo Fernández
LinkedIn
Rail Community
