- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently, the Elevation target only works in a only one way. It would be good that Civil 3D provides 2 options (2 ways) to provide the elevation to the subassembly. Nowadays, Civil 3D works as the left side (the elevation of the design profile in that station) is dragged to the edge of the subassembly, whereas it would be interesting like the right side one (the new elevation of the subassembly edge is calculated by interpolation (theorical projection) ).
Thus, it doesn´t have to create a new offset alignment (also used for the Horizontal target) with its corresponding design profile to obtain the properly elevation for the subassembly.
So, in a corridor Region, for a subassembly, you can choose one of the 2 options for the elevation target.
I attach a drawing file which is the source of this screenshoot.
Please, Autodesk staff, remember this improvement.
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
