*** My alignment doesn't create offsets 😢😢😢 ***
s.sajjad.jafari
s.sajjad.jafari
Hi every body,
I have a 500 km alignment but when I want to create 3250 m offsets it doesn't allow. The alignment just allows up to 190m offsets. What's the reason?
How can I solve the problem?
I need this offsets ranges due to my base map scale.
I also attached the file
I'll be so appreciated if somebody could help me 😢
Pointdump
Hi @s.sajjad.jafari,
"The alignment just allows up to 190m offsets. What's the reason?"
Because most of the curves are 200 Meters. You can't offset an inside curve more than its radius.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
neilyj666
500km alignment....wow that's big.... and 3250m offsets too.!!!! What are you designing?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
tboehler
Like the previous poster noted - the radii are to small at some locations.
Attached is an offset (polylines) of the alignment after exploding it and joining it back together.  The offset removed some of the smaller arcs.  These polylines may help you - maybe not.  You can make alignments out of them.
You can insert them into your drawing.
Joe-Bouza
if the alignment is that balloon, your geometry maybe restricting the amount of offset
Joe Bouza
s.sajjad.jafari
Thank you so much for your answer 😍
