MUTCD sign blocks / library?
deltacoolguy
deltacoolguy
I'm looking for a relatively simple, yet accurate, sign library for the common MUTCD signs for plan production.  The sign itself needs to be graphically shown.  For the most part I don't need anything customized.  For some reason, I'm having a hard time finding something that is relatively simple to use.
Also, just curious, if you were doing a plan set with sign graphics, which would you rather work with?  Graphic files (i.e.: jpegs, etc.), or AutoCAD blocks?  I'm thinking I'd rather use AutoCAD blocks, as I could then explode and modify them if I needed to.
Windows 10-64 Pro
8GB RAM (Home)
12GB RAM (Work)
AutoCAD Civil 3D 2019
Replies (30)
andrewpuller3811
You cant just rename eps file as dxf and open them.
From mdj793 post above -
"To get these into DWG, use Inkscape to open EPS file, save as DXF. Then open in AutoCAD."
Your best bet would probably be to download the microstation format cell files and import them into autocad as suggest by mdj793.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
CADMark software has autocad blocks of traffic signs. www.pespasystems.com
evaneviecroft
Community Visitor
Community Visitor
Made my life so much easier with this file! Thank you!
Thank you so much for sharing.
LT
sbragaGMH4T
Community Visitor
Community Visitor
You are an angel on earth
romney_degena
Community Visitor
Community Visitor
Anyone has a W2-14A sign? please assist, I need it. Thanks.
ahmad_aoun995
Community Visitor
Community Visitor
_Bilal
Mousumy_X_Akter
Community Visitor
Community Visitor
Any update on this file as of 2024?
Mousumy_X_Akter
Community Visitor
Community Visitor
Any update on this as of 2024?
Mousumy_X_Akter
Community Visitor
Community Visitor
Any update on this?
