Civil 3D Forum
Multiple Section problem
5 REPLIES 5
Alas_1234
559 Views, 5 Replies
  Hi everyone,
I am working on river project . I created first aligment, profil and redline- sampliline- corridor. There is no problem up to this stage, but when I try to create section view, it gives wrong and single section as can be seen from photo 2. I can't create multiple.
I worked on other project and I haven't this problem (photo3) .  What is the problem about my project why gives wrong section?
Also I attached .dwg file as a working project(worng one) and old project(true section).
5 REPLIES 5
in reply to: Alas_1234
Try setting changing the annotation scale from 1:100 to 1:200, then select a section, right-click and select Updated Section View Layout.
Look at this post for reasons why this is happening: https://forums.autodesk.com/t5/autocad-civil-3d-forum/cross-sections-stacking-on-top-of-eachother/td...
Alas_1234
  Thanks rdlongbow, the section turns to multiple view. But this times, Elevation and distance value doesn't seem on the sections. İt is all empty. When I use same section style on other projects, it gives elevation, distance and assamble value. But my project sections are blank.
I went into the sample line group properties > Sections > Sample more sources and brought sampled everything available and got populated section views. You know what you are looking for, so that should do it for you.
Alas_1234
Huge thanks. It works!
Alas_1234
Rail Community
