Multiple Corridors that target each other
wgaerdes
Message 1 of 8
wgaerdes
I have a meandering channel (1st corridor) with a walkway on the one side (2nd corridor) and rear yards on the other side (3rd corridor). I'm having a hard time modelling this since there are a lot of variable. For example if the meander is close to the walkway there would be a wall, otherwise there would be a 2% slope towards the channel. On the rear yard side there could be a wall when the meander is close to it or a 2% slope towards the rear yard and a 3:1 slope to the channel.
I'd appreciate any suggestions to solve this please.
Replies (7)
Message 2 of 8
VincentSheehan
Could extracting the Feature Lines from one corridor and target the Feature Lines with the other corridor? Keep the Feature Lines dynamic.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 8
nkiakas
Hi @wgaerdes
This one loos like have to make you own subassemblies in SAC
When the typical section has "if...then", because you said if its close, then 2%, otherwise something else.... means you need your personal subassembly(ies).
Give me please more information regarding your typical section
Message 4 of 8
wgaerdes
Hi @nkiakas
Here's the subassembly I have created for the channel. Apparently they don't allow *.pkt file to be attached.
Message 5 of 8
nkiakas
Can you attach it?
Message 6 of 8
Udo_Huebner
Please upload additionally a DWG file instead of only a JPG file. And you can upload almost all file formats if you just zip them.
Gruß Udo Hübner (CAD-Huebner)
Message 7 of 8
wgaerdes
Hi Udo
Here's my drawing
Message 8 of 8
Jeew-m
I think you should go with conditional horizontal target assembly in this scenario.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
