Multileader Style Tab without Using Manager to Set Current Mleader Config
s it possible to match the Multileader selection to set the configuration different in 2018, rather than having to open the manager, select configuration and then 'set current'?
I like how easy it was in 2014, but perhaps my CAD manager set this up differently when we moved to 2018.
2014
2018
cwr-pae
That section of the annotate tab of the ribbon still exists. There are also two tool bars with the control list. (Styles and multileader)
Can you provide direction to enable the ribbon if not configured properly? Or point me to where I might turn this on?
jeff_rivers
@cwr-pae I'd like to know where this toolbar is hiding too. I searched the CUI for it, but didn't find it.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
cwr-pae
cwr-pae
CUI - Its a little confusing to use at first, but a little reading/research in help should guide you through the procedures.
cwr-pae
If you have a tool bar loaded, right click in the grey area, pick ACAD and you can find them that way also (can't screen capture the menu when its open)
