Civil 3D Forum
Multileader's Arrowhead Placement Seperate from Leader
8 REPLIES 8
Message 1 of 9
Grimes_MG
704 Views, 8 Replies
So the leader in the following picture shows the arrowhead attached to the leader as expected:
But when I open a template drawing I have created the same multileader displays as such:
Notice the extremely large gap between the arrowhead and the leader? What is defining this distance?
I have tried the ACAD built-in blocks (_open, _origin2, etc.) as the arrowhead and they all display with the gap. What gives? I'm seeing this in C3D 2015, not in C3D 2013.
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
8 REPLIES 8
Message 2 of 9
Jay_B
in reply to: Grimes_MG
In the 2nd screen shot, is the linetype used "continuous" ?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
Grimes_MG
in reply to: Jay_B
Thank you for your question. The Multileader's linetype is set to "By Layer" and the layer's linetype is Continous.
Message 4 of 9
Jay_B
Very strange, can you duplicate the issue by creating an mleader style, in a dwg using the ootb, acad civil imperial NCS .dwt ?
Using the above template in I can't seem to replicate the issue here using 2015 SP1.
C3D 2018.1
C3D 2016 SP4
Message 5 of 9
Grimes_MG
in reply to: Jay_B
I've confirmed that only this drawing has this issue. Is there a drawing setting I'm missing?
~Michael
Sent from my iPhone
Message 6 of 9
Jay_B
Posssibly a setting but nothing comes to mind.
If you can post a sample dwg, I'd be willing to see if anything clicks.
Only an mleader style with the issue is needed in the drawing and everything else can be deleted from the dwg.
C3D 2018.1
C3D 2016 SP4
Message 7 of 9
rl_jackson
if this is a custom block for an arrow I would suggest editing the block to make it annotative
Rick Jackson
Survey CAD Technician VI
Message 8 of 9
in reply to: rl_jackson
I take it the arrowhead is a block...   check the block's units, was it created in feet or unitless etc.  check your drawing units.  Verify the insertion point of the block.
Message 9 of 9
Jay_B
@Grimes_MG wrote:
I have tried theACAD built-in blocks (_open, _origin2, etc.) as the arrowhead and they all display with the gap. What gives? I'm seeing this inC3D 2015, not inC3D 2013.
It does appear the OP is possibly using a custom block for the arrowhead.
The original post states that 2 of the ACAD built-in blocks (_open, _origin2, etc.) , exhibit the same gap issue in the problem custom template.
C3D 2018.1
C3D 2016 SP4
Rail Community
