Civil 3D Forum
MULTI LEVEL SLABS/VERTICAL CUT AND FILL [RT Walls]/SITES/GRADING GROUPS - HELP!
4 REPLIES 4
christopher_c_donovan
895 Views, 4 Replies
Landscape Architect working on a complex 'Study' project - a residential site on a steep slope.
Details:- +/- 4Metres [12ft] Front to Back. House and Garage almost touching  [connected by a small corridor] and on different levels [+/-0.5 Metre]. Two driveways one to Garage Forecourt on Side of House  and the other  up the other side of House going around to visitor parking at the back.  There are many retaining walls and 'flat' garden areas stepping back up the slope. [see JPEG image Segal House]
Project is existing and built but I am studying it to apply what I have learnt after going through Mastering Civil 3D - I am of the Old School pen and paper / Parker and McGuire Simplified Site Engineering/Able E Munson Construction Design for Landscape Architects  School. To keep it simple my aim is to create a Proposed Finished Surface to enable
Cut and Fill Analysis and Design of all the surfaces/spot elevations proposed contours etc in the 'traditional' way. I am not after the structural design of the Retaining Walls just their effect on Cut and Fill - how high they should be etc.
Project looked very interesting and exciting to take a stab at - you guessed it I have run into a wall [both literally and metaphorically]  HAVING PROBLEMS SURFACE MODELLING THE RETAINING WALLS - to all intents and purposes VERTICAL CUT AND FILL no?   I have created a simple Grading Criteria for this [thanks you guys and galls out there in the wide blue yonder] namely:  Target:- Surface  Slope:- 0.01:1  [RTW]
Trialed it  on single feature lines - had it turn corners and work in Cut and Fill. Got excited tried applying it to Target surfaces other than Existing - it did! - So jumped right in feet first.  And here we are back at the drawing board.
I have created a simplified drawing of three interlocking slabs/pads [called SHAPES 1-3 in attached dwg] at three different levels on three different SITES. I have created 3 separate Grading Groups for each SITE and used the same RTW criteria on each site. NB The perimeter of each Slab is a single connected Feature Line - not sure if this might be the source of some of the problems [I understand the need to keep Feature lines that touch in separate Sites - just trying to get the RTW critieria to work for the moment]
In the model attached I have applied the RTW criteria as follows:-
Source: SHAPE1/applied it from A-B/Target: Existing Surface - result: WORKED
Source: SHAPE2/applied it from B-C/Target: Existing Surface - result:  WORKED
Source: SHAPE2/applied it from B-D/Target: SHAPE 1 - result: FAILED
Source: SHAPE1/applied it from D-A/ Target: SHAPE 3 - result: FAILED and Surface SHAPE 1 looks like it has 'collapsed' either into SHAPE 3 or to the Existng Slope. Note SHAPE 2's surface is still horizontal.
There are a helluva lot of questions here aside from the immediate one of why doesn't the criteria work B-D and D-A
1] I don't know that even if I succeeded in applying the criteria I would be able to merge the individual surfaces into a composite given that  feature lines DO! touch.
2] Is my workflow for this problem - namely:how to tackle multiple adjacent slabs at different levels - completely out to lunch?
3] Can complex surfaces such as these be merged and made to act as one so that you can compare  Cut and Fill just by adjusting sections of the Proposed surface [ie Top Parking 'bit'] against Existing surface or do you, as in the Old Days, have treat each area separately  X Fill/Cut for Top Parking +/-  Y Fill/Cut for House slab = A [too much /too little] - now lets try the Garage Forecourt [I am being necessarily simplistic here].
In short is my ultimate aim- to have it all working as one - too optimistic for Civil3D to create on such a site?
Any thoughts gratefully received - currently stumped and running out of ideas!
 Chris Donovan
4 REPLIES 4
I can't answer all of your questions now, but I've made a few edits to show how I would approach this.  Where two slabs are separated by a wall I don't let the featurelines which represent those slabs touch.  Instead I separate them so that one stops at the top/back of wall and the other stops at the bottom/toe of the wall.  Using an Infill to create one surface for all of the slabs is simple enough.
For the wall grading around the entire structure I cheated a bit, and added another featureline on a separate site.  That one is graded to the surface at 1/10  If I wanted to to the whole thing properly I would have cleaned up the duplicate FL vertices, put everything on one Site and used more Infill objects to show all of the internal walls.
Steve
Please use the Accept as Solution or Like buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: christopher_c_donovan
If I can attempt to take Steve's excellent advice a step further, move the flines to the same site as the gradings and add an Infill to get this.
Thanks for your reply
Essentially you are saying:-
1]Don't use the Grading Criteria/Grading Route to solve this problem?
Instead you are saying:-
1] Offset Top and Bottom of retaining wall Top Line= A-B Bottom Line C-D?
2] Join A-C and B-D with Feature Line?
3] Infill space/rectangle  ABCD?
Presumably where you have 3 or 4 slabs 'coming together' you will end up with triangular/wedge shaped
areas to be infilled in these corners?
Please note I can't read your drawing - I am working in Version 2016.
Going to give this a whirl.
Thank you - Gentlemen!
Got it to work as per your instructions.
Attach a sample
Rail Community
