Mult View Block tool missing
shashimanandhar1417
Message 1 of 11
shashimanandhar1417
Hi, I wanted to create a multiview block. But I could not find the Multi View Block creation tool (see attached). I am using Civil 3D 2016. I have checked on Civil 3D 2018 as well. It is missing there as well. Could some one suggest how do get the tool.
Replies (10)
Message 2 of 11
Jay_B
Try entering Command: MvBlockDefEdit
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 11
shashimanandhar1417
Hi Jay_B,
Thanks for your quick reponse. When I tried using the command MVBLOCKDEFEDIT,  it asks to select Multi-view Blocks and apparently I don't have Multi-view block to select.
However I have used command MVBLOCKDEFINE. With this command I have created multiple blocks with different views (See attached). I looks like the Multiview block created but when I "Insert Block", there should be option to select between standard block and Multi-view block. But in my situation I do not get such type of dialogue box. I just get only standard block option. Any suggestion.
Message 4 of 11
Jay_B
I'm not aware of the option to select between standard and multiview blocks using the Command: INSERT.
Both block types appear in the listing when using Command: INSERT (in 2018) but no option to filter them.
To verify what Mvblocks exist in the current drawing a list can be obtained by Command: MVBLOCK > Definitions
C3D 2018.1
C3D 2016 SP4
Message 5 of 11
shashimanandhar1417
As in my previous posting, I can't see the Edit Multi-View Block Definition tool on my Block Ribbon ( snap shot of the tool as seen on a youtube video attached). Could you suggest how do I bring in that tool on my Civil 3D Block Ribbon.
Message 6 of 11
shashimanandhar1417
Sorry I forgot to attach the Snap shot. Here is the one,
Message 7 of 11
shashimanandhar1417
Hi, Could anyone help so that I can get hold of the Mult-view Block definition Properties Dialogue Box as I saw on other demonstration video (see attached) which is missing on my civil 3D.
Message 8 of 11
shashimanandhar1417
Hi, At last I managed to bring the missing Mult-View Block Edit Tool by entering on the command "Toolbar" and just drag and drop the tool on to my menu system. Thank you anyway. The problem solved.
Message 9 of 11
yours was the only post that helped me with creating a MVblock.  With Civil 3D turns out the only way was finding the command.
Message 10 of 11
Hi, I’m having exactly the same problem and I’m still struggling with how you managed to add the from the cui?  Any chance of walking me through it?
Cheers
Message 11 of 11
Kristy_Cho
Community Visitor
Community Visitor
Having the same problem. Type MVB... in the command line. All commands start with MVBLOCK, e.g. MVBLOCKDEFINE, MVBLOCKADD etc.
