Moving points using provided northing/easting coordinates
Message 1 of 9
Hello -
I've never had this problem before.  I recieved field surveyed coordinates and would like to move points to the correct location.  The base drawing was provided to me by a surveyor and is in the correct coordinate system.  I've put locations on the excact drawing in the past.
For some reason I no longer can move these points to the correct location by typing in the northing/easting.  I can point to the exact location with my cursor but the point ends up no where near the correct location.
Setting problem?
Replies (8)
Message 2 of 9
Sorry 2012
Message 3 of 9
Pointdump
J,
Welcome to the Forum.
Need more information. Please elaborate on "move points to the correct location". Did you try the ALIGN command?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 9
In the past i was able to simply use the move function followed by entering (typing) in the northing and easting coordinates.
So I would snap and use the move function from the center of the object, in this case a circle.  Type in the coordinates 194, 80 and enter.  The point ends up no where near the correct location.
I think it might be a units/settings problem but I can't correct.
Message 5 of 9
civilman1957
Is your UCS set to world? ddunits set to decimal?
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Message 6 of 9
Just checked and yes to both.
Message 7 of 9
Pointdump
J,
"In the past i was able to simply use the move function followed by entering (typing) in the northing and easting coordinates."
Nothing has changed in that respect. Please post your drawing and show what you want moved and to where, so we can test it.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 9
Before I figure out how to post the actual drawing maybe this will help.  Is it defaulting to displace the point at an angle even if I type in the NE coordinates?  It may be a simple fix but this suddenly changed on me.
Message 9 of 9
Pointdump
J,
OK, I see. Default asks for distance and angle. If you type a # in front of coordinates, it will work as you want it to. Thusly: "#5000,5000" will move the circle to 5000,5000.
Dave
Dave Stoll
Las Vegas, Nevada
