moving all elements (surface, alignments, corridor, pipenetwork)
F.Camargo
Advisor Advisor
Message 1 of 22
F.Camargo
Hello everyone!
How are you?
After finish all my project, i recieved a notification the cordinates of my project is wrong. I need to move a little bit all my drawing, and I don't know what to do that, cause I have some objects like surface, corridor and pipe network into my drawing.
Does anyone could help me, please?
Replies (21)
Message 21 of 22
MikeEvansUK
Ok so you have used another feature I do not use.
I learned in 2018 that using FLines as baselines was dangerous as it destroyed a whole model file.
That may have changed but as a rule I just don't go there.
It appears the corridor is targeting the featureline correctly but in the shifted coordinates. Not really sure why this would occur, possibly something to do with the programming used for a featureline as baseline.
I'd put this down to a software bug, perhaps make this file avaliable to AutoDesk support so they can confirm if they agree?
To fix, I'm afraid you'll need to amend every affected baseline, remove the target the add back in.
See below, I only did one but it's all good after.
If you are only using for 2d targeting then I'd be tempted to use polylines. In fact' even as 3d I'd use polylines then 3d polylines for level geom as they don't interact with one another.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 22 of 22
F.Camargo
Hi @MikeEvansUK
Thank you for take you time to help me.
I hope never doing that again in my projects. It's crazy! lol
"I'd put this down to a software bug, perhaps make this file avaliable to AutoDesk support so they can confirm if they agree?"
It's a personal file and I can't share, unfortunately. But I can make other file as an example if you want to.
"To fix, I'm afraid you'll need to amend every affected baseline, remove the target the add back in.
See below, I only did one but it's all good after"
I saw the result and worked fine! But I tryied to remove the target and isn't working, baseline isn't changed.
So, for that time I have to finish my project in the wrong coordinate and them export all to 2D and move to the correct coordinate.
Thank you again and God bless you for the help.
I am going to accept that topic as solution!
Fabricio
