Civil 3D Forum
More Wierd Grapics
5 REPLIES 5
339 Views, 5 Replies
More Wierd Grapics
I have been experiencing similar weird graphical issues to T. Rogers. "weird graphics"
This started after I installed C3D 2016 SP3 recently.
The weird pixelation is random and changes as I scroll or pan. It happens in both model and paper space. Sometimes it occurs when I plot to PDF.pc3.
The image is inserted to the drawing as an XREF attachment.
Has anybody else had this experience after installing C3D 2016 SP3?
Does anybody know of a solution apart from uninstalling SP3?
5 REPLIES 5
GTVic
I've seen dashed line patterns not showing around spirals in 2016 with "High Quality Geometry" enabled. You could try disabling that to see if there is a difference.
GTVic
in reply to: GTVic
Also, this fix is available:
Autodesk® AutoCAD® 2014-2017 ECW Hotfix
in reply to: GTVic
Unfortunately the hotfix did not work though the documentation suggested that this might be my problem. The image in the XREF drawing is a .ecw file.
Thanks for the suggestion.
GTVic
Did you try turning off hardware acceleration or components of that? GRAPHICSCONFIG command.
in reply to: GTVic
Yes, I tried that.
I uninstalled Hotfix#4 and left SR#1 and performance is back to normal now.
Thanks for the help.
Rail Community
