Civil 3D Forum
More options about Resolving an Overhanging Corridor Surface
5 REPLIES 5
joantopo
406 Views, 5 Replies
Ok.
About this:
http://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/E...
There are 3 options:
-Top Link.
-Bottom Link.
-No link.
But imagine this scenario:
I have a "ShoulderExtendedAll" subassembly followed by a berm (LinkSlopeAndVerticalDeflection).
Perhaps in USA you link both subassemblies from the bottom point but in Spain we always do it from the Top of the extended shoulder.
So, if we use the "Top Link" the results are not satisfactory:
( the extended shoulder slope / or extended lane slope) is not the TOP for us).
With "No link" the result is the same.
In this case, we need this for the "corridor surface (TOP)" , the red one: ( I painted the red line on the screenshoot).
Perhaps, to solve this, Civil 3D should have more options about Overhanging Corridor Surface, to resolve this scenario.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Labels (1)
5 REPLIES 5
joantopo
in reply to: joantopo
Observation: The "LinkSlopeAndVerticalDeflection" has the link codes: Top,Datum.
joantopo
For some reason, the "LinkslopeAndVerticalDeflection" doesn´t work fine at all.
When I open the drawing it appears correctly, but when I regenerate the corridor, then appears again wrong.
I have replaced that subassembly with my own subassembly (made in SAC) and it always works as I expect.
Peter Funk
Autodesk, Inc.
We'll take a look at that SA. When I tried it I used "LinkWidthAndSlope" and set the slope to match the slope of the shoulder and it worked fine
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
robert06
X its an edit.
i can't find a way to delete my comment here..
Rail Community
