Civil 3D Forum
MOO'S: WHAT CAUSES THEM
8 REPLIES 8
Message 1 of 9
Joe-Bouza
616 Views, 8 Replies
I know how to clean them up, but what can I do in my work flow to avoid them?
I've been working on a 2 mile corridor and this is the 4th time they have corrupted my file
Joe Bouza
8 REPLIES 8
Message 2 of 9
Jay_B
in reply to: Joe-Bouza
Hi Joe,
What does MOO stand for?
Are you referring to a Mask 0 error or?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
Jeff_M
in reply to: Jay_B
Message 4 of 9
AlmasSuljevic
Hi Joe,
*Warning* Multiply Owned Objects error means that multiple operations are trying to access the same objects at the same time which creates this conflict. I've seen it happening with styles. Please see this:
http://beingcivil.typepad.com/my_weblog/2010/08/warning-multiply-owned-objects.html
I hope it helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 5 of 9
Joe-Bouza
in reply to: AlmasSuljevic
Hi Almas
I am familiar with the BC blog post on this. At this point I have already lost the assembly "visually" the construction tab still says they exist. Is there a way to get it back? Have you seen the files I sent in with the SR?
As for the multiple operations accessing the same object, this is confusing to me because the corridor file refs EG for the OML2 sub and several offset alignments to control tapers and widths. Thats it.
I'll go and begin version 5 but I fear Ill end up in the same place with the firs 4 versions each one ending the same way.
Here is another oddity. The assembly in the copy file from the day before that shows will not WBLOCK out or Clipboard yet the others do. So every version I do I have to remake the assembly. Not that big a deal but annoying.
Joe
Joe Bouza
Message 6 of 9
Joe-Bouza
here is the wblock of tyhe assembly. Check the construction tab
Joe Bouza
Message 7 of 9
Jeff_M
Joe, all of the subassemblies for that assembly are located near the origin of the dwg. They can all be moved (select, rt. click, move to) back to where they should be on the Assembly. Not sure how, or why, they became located so far away from the assembly.
Message 8 of 9
Joe-Bouza
Whoa!
Awesome find Jeff
That must be the Moo's working hard
Joe Bouza
Message 9 of 9
Joe-Bouza
in reply to: Jeff_M
Hi @Jeff_M and @AlmasSuljevic
Jeff,  that was a great find. The good news I was able to reconstitute the assembly with the move subs command. The bad news, the corridor was whacked the subs were all crisscrossing and ignoring targets.
The good news: making a new assembly and copying the subs worked. I have my two mile corridor back with all the transitions in tact.
Almas, I think my MOO's was caused by me setting the OML2 sub in the assembly in layout mode defining the crown offset and overlay trim and then adding a alignment horizontal target to the corridor as I progressed. I'm not sure of that and would welcome your opinion back.
Joe Bouza
Rail Community
