Modify swept path
Modify swept path
pics.munmun
Modify swept path
pics.munmun
Please refer attached image:
Neilw_05
The swept path tools are too finicky to worry about 1 inch. In most cases if you try to adjust the path by moving a grip even a small distance, the entire path dissolves. I would not bother with trying to fix a path that is off by an inch. Call it good.
In my opinion, Vehicle tracking is horrible with regard to grip edits after the path is completed.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
jroot
That number does not plot but to turn it off you need to select the vehicle path and click on the Report Wizard on the Ribbon:
Then uncheck the box "Construction lines visible":
Neilw_05
Lol, totally misunderstood. Didn't see the label in the dark background and thought you were worried about being 1" too close to the edge.
WIN 10 64 PRO
jroot
I didn't see it either till the third glance, but your misunderstood comments about Vehicle Tracking being finicky were spot-on 🙂
