Civil 3D Forum
Mleaders - fully filled text frame?
2 REPLIES 2
camden.n.dean
183 Views, 2 Replies
camden.n.dean
I have a bunch of mleaders that I was asked to mask.
If I just turn on text masking on the properties palette, it looks bad because the mask is smaller than the frame.
Bad example:
After googling, I figured out how to adjust the mask for a single mleader, but this is an untenable solution for me because i can't do all the mleaders at once.
Is there a good way to make the text mask be the same size as the text frame? I just want some form of a wipeout that will look better without having to change each mleader individually.
Good example:
-Camden
Bad example:
Good example:
-Camden
Tags (2)
Labels (2)
2 REPLIES 2
rl_jackson
in reply to: camden.n.dean
rl_jackson
If you have gotten one like you want, then you should be able to match properties to make the others work along the CCCL.
Rick Jackson
Survey CAD Technician VI
Rick Jackson
MMcCall402
MMcCall402
Select your mulitleaders and set the Landing Gap in the properties window to be 1/2 the text height.  That should shrink the frame to match the text mask.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Mark Mccall
CAD Mangler
Linkedin
Rail Community
