Civil 3D Forum
Missing .pkt file
2 REPLIES 2
1760 Views, 2 Replies
Missing .pkt file
I created a number of sub assemblies in sub assembly composer and imported them into c3d, unfortunately I didn't make a copy of the package files and kept them on my hard drive, my hard drive then corrupted and I cant retrieve the sub assemblies package files.
Is there anyway to re create them from the installation files once a package file has been imported into c3d?
2 REPLIES 2
chriscowgill7373
a pkt file is just a zip file.  You could try to recreate it.
in c:\program data\autodesk\ c3d XXXX\enu\imported tools
all of the pkt files you have used should have foldernames
Within the folder are 7 files that are included in a pkt file:
*.atc
*.cfg
*.dll
*demd
*.pvd
*.xaml
[Content_types].xml
You could try to zip them and change the extension and see if that works.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
in reply to: chriscowgill7373
I read that somewhere literally 5 minutes after I posted the question; it worked for one of the sub assemblies, the other I had to open in composer and resave with a different name but worked after a few attempts - Thanks
Rail Community
