Mill and Overlay Subassembly
dcarucci
Observer Observer
dcarucci
Observer
Observer
Is there a subassembly that you can grind and overlay 2" from the existing surface and hold the existing slopes. It seems the only options has the overlay going back at a design slope not matching existing.
ecfernandez
Hi @dcarucci, I am not sure there is a subassembly to do that. However, I am sure you can program a subassembly with Subassembly Composer. You should give it a try. If you do so and you have any questions about it, please post them here in the forum to help you.
Best Regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
Joe-Bouza
OverlayMill2 matches existing
these subs are very dependent on the acuracy of your survey and where you define the trim point
Joe Bouza
Joe-Bouza
Rehab subs Mill and overlay
Joe Bouza
